Correct way to connect multiple AMS and HT to an H2D
I have x1 H2D, x2 AMS Pro 2 and a HT. I have a couple of 4-in-1 adapters and a couple of spare 4 port buffers. Currently the HT is connected to the lower H2D PTFE port and the AMS2 is connected to the upper. I’d like to connect two AMS2 to the upper port. Not exactly sure how to do that without if looking a janky.
I cut a super short piece of PTFE that just fits in the H2D port and the 4-in-1 adapter. Due to the piece being so short the 4-in-1 doesn’t really sag. There are several mounts on MW if you want it to look more professional. Then you just run both AMS 2 Pros PTFE in to the 4-in-1 and plug the second one’s cable in to the input of the first one you already have connected.
Thanks for that info. Like I used to tell my soldiers, reading is fundamental and I admit I didn’t read enough as I found a really great explanation on the Bambu Wiki right after I posted that picture. Geez. I will certainly check out those Maker World prints too. Thanks again!
