Hello Bambu Lab team,
I would like to suggest a feature that would allow users to combine two different support types, with independent settings, on the same model and in the same print.
For example, when printing a complex mechanical part, external areas may require Tree Supports with PVA interfaces, while certain internal areas, such as a narrow, partially enclosed C-shaped gasket groove, may require Normal Supports made entirely of PVA.
1. What we want to achieve
The idea is to keep the existing Supports system unchanged and introduce a second support configuration called “Custom Supports”, identified by a different color, for example Cyan.
Both support types could be used simultaneously on the same model:
Standard Supports: Tree Supports with PVA interfaces.
Custom Supports: Normal Supports made entirely of PVA.
Custom Supports would have their own settings section, using exactly the same parameters and interface as the existing Supports section, but independently configurable.
This would allow users to choose different support types, materials, patterns, spacing, interface settings, and distances for each configuration.
2. How to assign Custom Supports
The existing Support Painting tool could be extended with a new button called “Make Custom Supports”.
Users would simply paint the desired surfaces using the existing painting tools, then click this button to assign those areas to the Custom Supports configuration.
The assigned surfaces would be highlighted in Cyan to distinguish them from standard support regions.
The existing Support Painting functionality would remain unchanged, allowing both support configurations to coexist on the same model.
3. Slicing Results – Line Type
After slicing the plate, “Custom Supports” would appear as an additional entry in the Slicing Result → Line Type list.
This entry would use its dedicated Cyan color and have its own visibility checkbox, allowing users to show or hide Custom Supports independently from Standard Supports.
The slicing statistics would also distinguish between the two support types, including printing time, material length and material weight.
Benefits
Two different support strategies on the same model.
Fully independent support settings using existing parameters.
Simple assignment through the existing painting tools.
Better support placement for complex mechanical parts.
Improved surface quality in difficult or confined areas.
Reduced support material waste.
Better use of dual-nozzle and multi-material printers.
The goal is not to introduce a complex new support management system, but simply to add one additional, independently configurable support type, using the tools and settings already available in Bambu Studio.
Note: The screenshots were captured from the French version of Bambu Studio, but the proposed modifications and new features are shown in English. These images are mockups illustrating the suggested functionality, not screenshots of an existing feature.
Thank you for considering this suggestion!
