"CUT" Option - help
Anyone know how to hide the white drop down menu when you choose the “cut” option? The reason why I ask is that that drop down really makes it hard to be precise.
2nd Part of this is how to I say rotate the z axis by a set degrees such as 90 degrees or 180 degrees. I get that it is not necessary, but it would be nice to have everything clean and exact! Yes, I am being nitpicky… I’m old :slight_smile:
I attached a screen shot of the menu I am talking about as the answer is not “Shift - tab”, or can i find it in the “keyboard shortcuts”. And lastly, while I am on this note about editing part colors, is there a complimentary product to Bambu Studio for more “detailed” options for edits? I think I am beginning to learn the limitations!
Thanks for your help/guidance…
https://wiki.bambulab.com/en/software/bambu-studio/cut-tool
When you rotate, there are guidelines at 45, 90, etc… so place your mouse on the desired angle or type in the desired value as shown on wiki.
I feel your pain, the Studio UI isn’t always perfect…
Sometimes I miss old days…
You know, the times when programmers got creative and tried things like detachable menu/tool bars…
At least a little tick box in these protruding windows would be nice - tick it to make the thing transparent…
Rather than moving the window, use your middle mouse button to pan the model back into the open area. If you’re on a laptop, I’d recommend getting a mouse you can use as it makes life easier :slight_smile:
You can also click the cut icon (in the menu) again to hide itwithout cutting to preview. It shouldn’t loose the settings. When you click it again to show the menu you can further refine the cut until you get it just right.
