Cutting Module, are those bugs or features?
@SupportAssistant, When using the cutting module, when the cut or the drawing is completed, the toolhead is stuck because the stepper motors are still energized and never de-energized unless you power off the printer, is this a bug?
When you power off the printer, even if the cutting module was attached prior to power off, the printer requires a cutting module calibration at power on. Again, is this a bug or a feature?
