I have a Bambu H2D, but not the laser version. I purchased the optional cutting module separately, but now am looking to also add in a birds eye camera. However, I’m curious (from those that have a birds eye and cutting module) whether certain features are available.
I’m primarily planning on cutting out trading card proxies, so it involves lining up a cut path outline against a number of identically shaped printouts, that potentially have different contents, but always the same contour. I’m fine with placing the initial cut path manually using the birds eye, but I’m wondering if there is the option to automatically replicate the cut path placement across more than one printout on the same sheet of paper.
For example, if I have a 2 x 4 grid of printouts, I want to be able to specify where the cut path is relative to one, and then have it propagate out the cut paths to the rest. It would seem similar to the Batch Engrave feature, but not sure if it’s supported with the cutter.
Thanks!
