Yes, I do. Infact, this prototyping work is being done in PLA to get the print right before making the final print in PETG.
Secondly, do you have an AMS on your P1? Saw you have the Combo. Thatâs good.
If you can share that model, I can setup a print profile for you that will guaranty the quality youâre looking for. Since you are going to print the final model in PETG right?
Yes, thatâs right (the PETG final). How would I get the model to you?
I just PMed you. Iâll provide you the details later in the day once I got your file, I need to head out pickup my family member.
So, here you set your PETG and PLA. The 3MF file in the same place where you uploaded. PLA and PETG donât stick to each other after cooled down, so you can increase the density of the interface support.
I use the PLA as interface for the PETG - the red one for you to see.
How it was done?
The trick here is that you select any of these 3 filaments even you donât have it.
Then at the Support area (Advanced turned on), pick that as interface. The software will automatically adjust the setting.
Then go back to your filament selection pick back your PLA.
This is to trick the software thinks that you are using Support filaments.
You can do this vice versa opposite as well.
Astonishing detail and assistance. Thank you so much for taking the time to look at this, itâs hugely appreciated. Will try and look at this again tomorrow but about to head out on a road trip for a week, so will comment once I have had a chance to look at it.
I have learnt so much just from posting this one topic and reading the responses. Just amazing!
Hi Folks. OK, so thereâs a word I use every now again, but itâs not common.
The word is âFlabbergastedâ.
I got some time to look at the file and instruction set sent by @kip yesterday. To be honest, I donât completely understand whatâs going on here, but I put my best âparrotâ face on and just copied the instructions as they were supplied.
I used the same eSun PLA+ as the support and my Generic PETG as the main material. Then I tried to print the model.
This is where the word âflabbergastedâ comes in.
This is the print as it came off the textured plate, with the supports in place.
These supports came off easier than any support I have ever used. A little finder pressure and âpopâ, off they came.
This is the resultant print.
⌠so, Flabbergasted.
I need to go over this again and fully understand what happened and why a support acts so differently. There was a half support spool in the box with the P1S-Combo, but not having used it before I put it aside for a rainy day.
As I mentioned, I am off on a week long road trip Monday, so may not get a chance to do a deep dive into this process, but itâs a generational difference that I will definitely be using again. It has helped me move forward with this project in a meaningful way.
Again, and especially @kip I canât thank you guys enough for your help and knowledge transfer on this subject.
Yea- his advice was very slick, I had read about using mis-match materials as support to take advantage of the lack of bonding between them, but had never tried it- and definitely didnât think of using it in your application.
Was a clever suggestion for sure!
Sometimes, support settings can be tricky. Have you tried adjusting the support density or using a different support pattern? Reducing the support contact Z distance might help make the supports easier to remove without affecting the print surface as much. Also, ensure your supports only touch areas that really need it. If those changes donât help, it might be worth experimenting with different filament brands or tweaking your retraction settings.
I wanted to ask a question thatâs directly related to the solution @kip provided.
Firstly, this method of printing dissimilar filament has been a complete game changer for my rapid prototyping work. I have now used it on several other prints, all with significantly improved results.
I want to be able to move on and print with ABS, for stronger parts. Itâs my first experience with printing ABS and I have just had a delivery of Bambu Basic ABS (Black) to play with. I tried to re-run the print job above only to get a warning from Bambustudio about not being able to print with filaments that require large variations in their ideal print temperature.
This doesnât seem unreasonable, but I am trying to decide how to address it.
If I am unable to mix PLA+ with ABS then should I just default to âsupport filamentâ, or will this also result in the error message.
Any suggestions please?
ABS and ASA uses HIPS filament for support.
