Disable importing profiles and filaments from 3mf files
Is there a way to stop 3mf files from adding filaments and printer settings whenever i open it? I just want to open the file without it changing to a printer I don’t have and using filaments I don’t have. It’s incredibly annoying to keep having to change the printer and remove all the new filaments to put back the settings to what I already use.
Use File | Import | Import 3MF/STL/STEP/OBJ/AMF… to just import the geometry
also create a random object lke a cube on the build plate, then load the file and it iwll ask you if you want to import geometry or replace the prokect. obviously you need to remember to delete the cube afterwards.
