Distancing supports from model
can anyone tell me how to distance the first layer of supports from the model? its always too close and ends up sticking.
For starters you should do a flow calibration and then pressure advance calibration.
Anything else you do before that is just masking the issue.
After that, in your supports menu there is a setting for x/y distance to supports you can change if needed - but you shouldn’t need to ideally.
