DIY temperature/humidity sensors for 3D printing
This is a fork from the Sunlu i10 thread, where we are developing some more accurate ways of measuring humidity at low moisture levels as a check on whether or not the i10 deliver’s on its promise.
However, it extends beyond just that and could benefit anyone who wants to accurately measure low levels of humidity inside any dry box. I encourage posts of any kind that are in any way related.
And it goes further than that too. The little MagTag thing with the display could be useful for other things too. I was going to bring up code with a VOC sensor, and possibly for some of the other sensors Adafruit has with STEMMA connectors. Their libraries can just swap out and the graphing and other bits are the same. I think the VOC version might be handy for some.
My code is all done and I’m just finalizing the model page. If anyone is interested they’ll be able to see it all once it’s up. All-up cost is about $40 plus filament.
The MagTag is an Adafruit product with an ESP-32 core and 2.9" grayscale 296x128 pixel e-ink display. It connects to a Sensiron SHT4x temperature and humidity sensor using a cable and connectors. No soldering.
It is powered over a USB cable, echos the sensor data over USB if you want to log it all to a Raspberry Pi or other computer, and has an audible alarm if alerts are desired for too high of humidity.
Temperature and humidity graphs are autoscaled to fit the y-axis and toggleable legends are used to show max and min values. The time axis for the graph is adjustable from 2 hours to 292 days. Each point on the graph is a measurement and with humidity you can choose to plot either the maxima or the averages. Maxima captures anything that raises humidity no matter when it occurs. Averages are collected just at the sampling times and can miss transient events. Maxima sees the highest point during a sampling period but sacrifices a small y-offset (0.2-0.5%RH) and not knowing when the maxima data was collected during the time period. Data are not time stamped.
There’s a four neopixel LED bargraph with user-settable humidity levels that is continually updated and turns from green to yellow to red as humidity increases. The bargraph auto-dims according to ambient light.
Anyway, lots of features. The MagTag has lots of capability built-in and a lot of it fit nicely with a temperature and humidity logger. If anyone is interested, it will be posted soon.
Typical OSHpark default purple PCB:
Looking at the picture maybe the thru-hole plating could be better, but, meh, probably good enough. More concerning is that the silkscreen didn’t label the holes for the connection pins, so I’ll have to work that out from the schematic. Or maybe I can just look to the current version for sale on AdaFruit to infer the correct labeling, assuming the pathways are the same.
Since I received everything ahead of schedule, I’ve got time to contact 3M to see if they have any suggestions on how best to validate whether the very specific Kapton I purchased is the real deal or not. If it turns out the vendor is an authorized dealer, they might be helpful.
I once contacted Nordic Semiconductor to check whether some chips I sourced from China were genuine, and they offered to x-ray a sample to get me a definitive answer. That was nice of them to offer, especially since I’m not a big shot customer. Maybe 3M has something similar. In return they get market intelligence to help them keep abreast if there are counterfeiters they should know about, so maybe they’d do it for that reason. It ruins their brand if someone out there is selling fake stuff under their name and it underperforms 3M’s claims, so maintaining brand integrity might be reason enough for them to care.
[Edit: Inspecting the PCB’s by eye, and the plating actually looks flawless. Any dodginess in the photos must be just camera or compression artificats. Just thought I’d clear that up. :+1: to OSHpark for what at least visually appears to be a good job. I used them quite a bit in the past, especially before jlcpcb and pcbway and similar came to market, and I never had a problem of any kind with their quality. ]
Also, regarding the Kapton tape, the proof of the pudding will be in the taste. If it works out well, I’ll have far more than I’ll ever need, so if anyone wants some, I’d be happy you send you a strip for the cost of postage alone. Whatever a first class letter is. That is, if you’re in the US. International these days isn’t something I want to tangle with.
I just discovered the SHT85 sensor, which looks very attractive for the application.
While front sheet accuracy is less than SHT45, it doesn’t rise at very low humidity and has the same typical ± 1.5% accuracy below 10%RH and better max accuracy of 1.8 vs 2.0 %RH.
The biggest advantage is that it comes mounted with pins that you can just plug into standard female pin headers. So the risk of screwing calibration during manual soldering is completely eliminated.
Maybe you want to consider it?
/edit: oh, one downside: it’s expensive, 37$ at digikey :face_with_diagonal_mouth:
I’m assuming you are addressing this to @NeverDie but since ambiguous I’ll answer too? Anyway, first off is I wasn’t aware of it and it does look like a contender aside from the price.
The bigger issues for me were keeping the sourcing to a minimum number of vendors, and availability of drivers already written. That was the biggest one. Second biggest was it is a pin connector and not STEMMA. I’ve seen interest in projects plummet if there is any soldering or special cabling. I was able to do my whole design with no soldering and just plug-in stuff, pre-made cables, etc.
But just personal observation, and call me cynical, but I bet most will have a hard time even getting to 10% RH in the Sunlu i10. Other cabinets apparently don’t go below 20-25%. (combination of wet filament and dehumidifying mechanism, maybe leakage.) I was actually a little surprised to see my dry air generator hit 2% (as reported by an SHT45) using up some old Drierite granules.
*Aggressively throws 10 pounds of alumina into the conversation*
Hehe - so very, very, true! Fresh desiccant will certainly crash humidity. The tendency however seems to be load up cabinets, AMS units, or spools of filament themselves with desiccants and then forget about them so they eventually transition from helper to destroyer - the dark side of desiccants (though not the desiccant’s fault).
Anyone know what Kris said that got his message flagged?
Precisely the reason why I would still use the i10 even with my own mountain of desiccant - if I forget about it the i10 will take over eventually.
That’s true but I suspect it will take some time just going by what happened during the tests with loading undried filament. With desiccants having so much more water holding capacity at any RH than filament, “wet” desiccant may hurt i10 performance for a long time.
Not really sure how it will all shake out but just drying filament well in the first place should eliminate the need for desiccant in there. But since many aren’t able to do that for various reasons, I bet many will be making containers to store desiccant in i10s.
Ironically, if the i10 works the way I think it does (and think reviewers have said) is the regeneration cycle timing is determined by cabinet RH%. Fresh desiccant will likely shut down the regeneration cycles and at least until the desiccant humidity value rises enough, it will be the desiccant removing water (and sieves too once humidity rises enough as all rise together). Not a big deal I think but I bet it will further extend the time on desiccant. Need to think it more through and might be missing something, but desiccant in the cabinet may significantly change how the i10 operates too.
More questions and tests… :grin:
This is precisely the behavior I would expect and count on. Whatever extra desiccant I have in there should top out at the setpoint of the cabinet, and barring a small blip when the cabinet takes over (maybe) should otherwise not end up contributing to humidity, simply due to the equalization of, say, 10% RH just no longer adding anything to desiccant mountain.
Ah. I see what you mean now. But I believe the presence of desiccant in the cabinet will raise the humidity above the setpoint.
The reason is more complicated but if you’ve ever messed with capacitors and square waves it may click.
In this case the square wave is the cycling of the dehydrator and the capacitance is the desiccant.
A square wave with no capacitance on it is square. But increase the capacitance and the square waves start rolling off and losing the square part of the wave. Keep increasing capacitance and a square wave turns into a sine wave and starts losing amplitude. Enough capacitance and the square wave turns into a line at the average value of the wave.
But in the regime you’re talking about, there would be rounding - not necessarily amplitude loss. But even with rounding, time at minimum humidity goes down and average humidity goes up.
I’d bet minor effect though. But anything that behaves like a desiccant, including filament, will have that effect. The question is how strong but with desiccant it will be much stronger than with filament alone.
But with active dehydration water will be removed and desiccant will dry. I don’t dispute that at all. What I suspect is that desiccant will affect the process negatively. It’s similar to saying the best performance will come from the cabinet being empty with no water sources.
I need to think more about this though. There’s lots to consider.
What’s different is with these, with each cycle the capacitance (water) should get smaller as bites are taken out of the water.
I posted a link to an (expensive) air quality monitor on Makerworld, no idea why it got flagged as spam.
It’s still a respectable chip. Prior to the HDC302x I might have gotten it instead. With shipping included, you can get it on a BoB for around $20 on aliexpress. It used to be someone was selling them on ebay for around $16. My original interest in it was because it could withstand higher temperatures, which is maybe why it has just a by-pass capacitor on the BoB and nothing else (aside from the chip itself, of course).
Was it the Project Aura AQ monitor? Anyway thanks for the heads-up!
If that’s it, I have been watching it though. It’s very nice. But as you said, expensive. Over $200 and I personally think it’s way overkill for monitoring dehydration cabinets. Many of the tests are meaningless in a closed unheated dehydrator cabinet. And as I was talking about it with @NeverDie, you have to be careful with VOC sensors - they need to be calibrated for the things you want to monitor to give valid results. The reason for that is different molecules cause different responses in the sensor and the sensor can’t tell them apart. Ballpark I’d guess still ok but people should be aware of the various sensor limitations.
The biggest reason for going much simpler is cost, though. The loggers I’m working on are all-in at just a hair over $40. I haven’t been able to find temperature/humidity sensors with a graph display for less than around $90 that still don’t have all the features I’ve crammed into mine. The big drawback to mine that I see is it’s a wired interface to the sensor that goes inside the cabinet. I’d bet that means drilling a hole for the wire and sealing it. The battery-powered stuff obviously doesn’t need a wire.
Plus, those i10 cabinets are small when you load them up. With my loggers the only thing inside the cabinet is the sensor and I’m hoping to attach it to the i10 door electronics housing since it has a fan in it to help quicken the response of the i10 humidity sensor. I want to use their airflow but won’t be able to make that mount/housing until I get mine to measure it (if it’s even possible).
Anyway, I think it’s just a different market. If it’s just one person, they are really talented, that’s for sure. It’s a nice project.
I have built the Aura AQ and I find it well worth the price, but it probably isn’t the right tool here.
Yeah, it was the monitor you mentioned. I came across it while searching for a Home Assistant setup and posted the link to see what people had to tell about it. Thanks for the insight about the VOC sensors, I don’t know too much about microcontrollers and IOT so far but the plan is to change this now I have a 3D printer.
Things are way easier now than it used to be. You’d have some sensor that produced a current, voltage, or resistance, you go through lots of gyrations and calibration, and you’d have a number.
Many sensors now have their own tiny microcontrollers, carry factory calibration, and just hand you calibrated and compensated numbers over a communications bus when you ask. Even better, places like Adafruit and CircuitPython have libraries where all you do™ is add high level lines of code to read the sensor.
It’s much easier than many may think to do this stuff now. It used to be tedious and hard to get good numbers. Now you just ask.
Not all sensors can be calibrated at the factory, though. VOC sensors are simple and non-specific so many chemicals can cause a response. Some may cause strong responses and some may be weak and there’s no way to know if you’re seeing a lot of something that is weak vs a little of something strong without some other method to sort that part.
The sensors are heated to cause the sensing reaction and you can differentiate somewhat with an array of sensors at different temperatures or maybe different sensing compositions, but it’s not definitive. In general though they do tell you if there are problems but if it’s somewhat blind to something bad, and you have some other chemical that’s not bad in there giving a stronger response, it’s an interferent and you can be oblivious to the bad thing’s presence.
Confirmed. I just checked, and for our purposes its RH sensor accuracy is so bad that it’s effectively useless:
Don’t shoot me for saying it. I’m just the messenger. :innocent:
