Does Bambustudio scales parts automaticaly...?
Hi… Is it possible that Bambustudio scales parts automaticaly…? It happened to me different times that when i load a stl (Lego bricks or parts) from tnhingiverse or printables that is described for a perfect fitting it does absolutely not fit as it seams it is scaled up…? The studs should have a diameter of 4.2mm, after printing they have 5mm… Any sugestions…?
Here an example: LEGO Minifigure Base (Stands) + Wall Mount by ntalekt | Download free STL model | Printables.com
Hi,
I opened one of the files and the studs are 5mm. I used the measuring tool in Bambu Studio and measured the edge at the bottom of the studs.
I don’t think there is any “auto-scaling”; these are 5mm from the beginning. If you want a smaller stud, I recommend scaling to about 84%.
/Magnus
