Drawing a straight line across circular object
I’m hoping this is the right place to ask this. I am working on this Festool clock - Festool Clock - and I must be having senioritis. I cannot figure out how to line up the “10” and “2” numbers so they are on a straight line on the saw blade. I know where on the clock face each number goes (30 degrees) but for the “9” and “3”, “11” and “1” , etc. are on the same plane. TIA
I’m old school too so this is how my female brain would give it a go……. get a piece of paper and fold it and then you want to line up the 12 and 6, then 1 and 7, 2 and 8, 3 and 9, 10 and 4, 11 and 5. I think the 10 and 2 will look a bit odd because one is double figures and one single… but if they are all centred from the middle of the clock they should be fine.
does that make sense?
That is the way I began, however, as a double-check, I had Chatgpt generate a diagram as a double check. Thanks
