I have a simple graphic. Technically, 2 color, but the one color is the same as my “substrate”. So, only adding one color. I’m not quite sure how to go about embedding this.
Essentially like adding text, but adding a graphic.
I don’t see a place to attach a picture here?
If you have it as an SVG file, this is how I’ve done it:
In the slicer, right click the part you want to add the graphic, chose "Add Modifier->SVG
Then position the modifer/resize it etc to where you want the graphic.
Right click the modifier you just imported and chose “Change filament”.
done.
Not SVG but I can convert it.
I tried painting but the filament didn’t change. I did NOT do “change filament”.
Thanks.
How to add a svg to the first layer of an other graphic and make it print well embedded in the print? thanks
