Hi!
So before every print I have this error code [1000 c001 030422]
Not sure why I have it before every print, and how should I get rid of it?
Thanks
This pops up when in the filament settings the bed temperature is equal or higher than the softening temperature.
You can lower the bed temp(s) there. However, in some cases, it can actually be useful to have a first layer bed temp at or even above the materials softening temp as it’ll improve build plate adhesion. Just keep your further layers cooler to avoid elephant foot.
I have seen this a few times. I’ve ignored it without a problem, but now I think it may be related to the filament used and the door position.
The X1C has a sensor to tell if the door is open or closed. Bambu recommends an open door and top for PLA, PETG, and TPU, especially if the plate is heated (non-Cool Plate). So, see if the warning pops up with the door open.
I’ll confirm, but I believe the door was open when I got those message, but I’ll notice next print!
Since I have the and, the top glass is always on tho.
Oh maybe that’s it. I used a print profile form maker world.
I’ll check if it’s show next print I slice myself!
I get that message every time I print from the SD card. Never get it when printing from studio. For what it’s worth I can send file, print it with no message, and print the same file from the Sd card and get the message.
So I sliced my own model with the same filament loaded in the ams and haven’t got the message.
Exact issue to me, but in my case, this pop-up always appears when I print a file from the SD. Any problem if the file is launched from bambu studio… ¿Any ideas about how to fix it? Thanks in advance!
It’s a common thing , can’t seem to get rid of it so I just ignore it as it does no harm , just annoying
