Error Message when uploading a model
Whatever makerworld have done with these new Conservative parameters is a total joke. there was nothing wrong with the old way when is this company going to start caring about the consumer and not just the money.
[Plate 2]: G-code conflicts detected after slicing. Please make sure the 3mf file can be successfully sliced in the latest Bambu Studio. If the file slices successfully in Bambu Studio, please try moving the wipe tower further from other models, as we use more conservative parameters for its generation during upload testing.
Ah - the prime/wipe tower bug.
I reported it a couple of months ago. I do a lot of lightbox lenses and they used to be fine with a wipe tower and we could control the size.
Now each color makes the tower have a bigger and bigger footprint until it interferes with the model and triggers that error.
I was doing the photo certify fire drill and ended up just deleting all the towers and uploading those models to get past it. I could not figure out how to get the new format towers to work.
I think it got worse. Now I’m testing over and over with no real solution. I sliced a file on every printer profile and it was fine locally, but I could not upload a single one.
They say they regenerate slicing with more conservative parameters during upload but will not share what those parameters are and are calling it platform security.
At this point it feels like brute force trial and error just to get something to pass.
I can’t upload images in here yet but here is the chat transcript I have with support so far (I was pretty upset at first): Support Ticket Information
Issue Type: MakerWorld - Bug Report - MakerWorld Website
Create Time: 2026-02-13 18:52
Issue Description
I don’t know what exact parameters your upload check is using now, but I have sliced my manifold file and tested it on every Bambu printer profile with nearly 10mm of clearance on all sides of the plate, prime tower, object, and excluded areas, and my model still will not upload. The site keeps rejecting it.
I am beyond frustrated at this point. Can someone please explain or post the actual guidelines instead of just saying it is more “sensitive”? Printers do not work off feelings, last I checked. They work off raw numbers.
Virtality
2026-02-13 19:07:13
I finally got it after testing the prime tower without the custom parameters, then moving it to where it fit, and then changing it back. This is very stupid.
The entire point of the profile is so I can give people a better way to print it. My models take up a specific space and position to maximize the printer, etc., but that does not work when you put a hard limit on the prime tower during upload validation.
What is the point of having adjustable prime tower parameters if they are just going to be overridden or rejected? Why not just control all the profiles yourselves if creators apparently cannot be trusted to configure them properly? This makes no sense.
MakerWorld
2026-02-14 02:13:44
Hi there,
Thanks for contacting MakerWorld Team.
We understand how frustrating this experience can be and apologize for the inconvenience this may have caused.
Currently, during the upload process, our system regenerates and validates the slicing using more conservative prime tower and boundary parameters. This is done to ensure broader compatibility and to reduce the risk of print failures across different printers, firmware versions, and user environments. There may be cases where a profile that slices successfully in Bambu Studio may still fail the upload validation.
We understand your concern regarding prime tower customization and the limitations this may introduce. Your feedback is very valuable, and we will forward it to our relevant team for further consideraation as we continue improving our platform and making it more user-friendly.
Thanks once again for being a part of Makerworld Community.
If you do not have further questions for this case, we will make the ticket as “closed”. Should you have any further issues, you may reopen this ticket by replying directly to this email. For new requests, please submit a new ticket through our support portal:https://makerworld.com/en/my/support/tickets
Best regards,
MakerWorld
Virtality
2026-02-16 11:53:39
The core problem still remains. The explanation provided does not include any actual technical parameters or measurable guidelines that creators can follow.
Saying that the system regenerates slicing with more conservative prime tower and boundary parameters does not give us anything concrete to replicate. What are those conservative parameters? What margin is being enforced? What minimum clearance is required between the prime tower and other objects or plate boundaries during upload validation?
Right now this feels like a guessing game. A file can slice successfully in the latest Bambu Studio and still fail upload validation with no quantifiable criteria provided. That makes it extremely difficult to design profiles intentionally, especially when layout and positioning are critical to maximizing plate usage.
If there are specific limits such as a minimum wipe tower distance, bounding box margin, or plate edge buffer enforced during validation, could you please provide those exact values? That would allow creators to design within defined constraints instead of relying on trial and error.
MakerWorld
2026-02-18 03:34:08
Hi,
Thanks for your detailed explanation.
We completely understand the frustration in such case without any measurable criteria.
Regarding the exact validation parameters/thresholds, we’re very sorry that we’re not able to share those detailed validation rules at this time due to platform security and operational safety considerations. Our team would continuously optimize based on data analysis and user feedback.
That said, we understand your point and we’re sorry for the inconvenience this creates. We will also share your feedback with the relevant team to highlight the need for clearer, more actionable guidance.
If you run into a similar issue again, please feel free to send us the 3MF that slices successfully locally but fails upload validation. And we’ll forward it to the team so they can review the case and improve the experience going forward.
Thanks once again for your understanding.
Best regards,
Makerworld
Virtality
2026-02-18 13:47:28
This is exactly the kind of response that makes this more frustrating.
If you cannot share the validation parameters, then what are creators supposed to design around? I am not asking for proprietary code. I am asking for a measurable limit. A clearance number. A buffer. Something concrete.
We are talking about wipe tower spacing, not sensitive data. Calling it a security issue does not land.
Right now it feels like we are expected to guess until it passes. I solved mine through brute force testing. That should not be the solution.
If there are no fixed parameters because it is dynamic, then just say that. I would respect that a lot more than framing it as security.
