i’m get this error code
DEBUG ID: ffa76a77-3efb-4381-9698-69fd7909e896
Time: 2026-01-17T02:55:16.559Z
i cannot use makerlab
it been like this for sometime is there any updates
A couple of questions that would help to understand the issue:
hi thanks for responding. i have windows 11 pc and it’s up to date on all of my apps and software
it’s not working on the bambu studio and it’s not shoeing any debug id
and the debug id is shown on chrome and ms edge
and this happens when i try to design anything makerlab (ex. vases) or parametric model maker and also happened when i try to customize models like keychainfor example
Thanks again
Ok thanks for sharing that info. Would it be possible to try connecting though another network? Given that you’re seeing the issue in both Studio and the browser, I’m wondering if it could be a networking issue
Thanks a lot. it’s the only connection i can use. i used the limited hotspot on my phone still the same problem.
But you still right it’s the connection most the time i don’t shut down my pc, i just put it to sleep. So when i restarted my pc everything worked fine. i’m not a network expert but it’s connection error network card.
And again thanks lot for the great help.
For 3 days now I can’t download anything I created in MakerLab. It takes 10-15 minutes and gives me an error as if I didn’t have internet. The internet works very well and the computer is good. I also tried at work on another network and the same problem.
не работает генерация моделей,есть какие то решения
Тоже перестала работать marker lab ((( пробовал и bambu studio и различные браузеры и с vpn и без(
I have the exact same problem. Not to blame your services, I’m having trouble to reach one specific bank account and bambu lab image to 3d service, just 2 of those. So I think It is an inside error of my computer even claude fable 5 is not capable to resolve, sadly.
mate, I have the same problem. have you every installed AdBlocker or Cloudflare warp like dns changer ? I’m suspicious about Adguard pro and cloudflare w.a.r.p.
do you have ASUS motherboard with killer lan adapter ?
my problem is maker lab is taking hours to generate image to 3d ? just started running very slow today had to cancel a generation and list credits, its still not generating my mosel at 2nd attempt
