Error with high temperatures on P1S
Hi all,
when i print filaments that needs high temperatures (around 260°) my P1S stops working, after 15/20 mins, with this error:
The hotend cooling fan speed is too slow or stopped
i tryed with PC and ABS with the same result. All PLA are ok.
Filaments are dryed (as you can see in the photos attached).
PC is bambu and i used its settings.
ABS is ESun and i used Generic ABS
This appens with all 3mf i used.
Thanks
So I have to ask, is the hotend fan spinning when you see the error?
when i print these types of filaments i hear a “different noise”, there is some fan that is spinning a lot i think.
I will try another print… ready to check the fan in case of error…
Thanks
