External spool ptfe connector
Is there a way to take off the external spool ptfe connector on the x axis?
When it does the xy mech sweep, it is the loudest vibrating part on the printer lol.
Your talking about the external spool holder on the back, and your talking about the part that holds the arm on? If that is it then you should be able to unscrew it. If you talking about the arm then it just pulls straight up. If this is not it then can you post a picture to clarify?
It shouldn’t vibrate at all. Make sure the PTFE tube is inserted firmly in the connector and try removing and putting back the PTFE guide.
