I have had my printer for a couple of weeks and was printing fine earlier today. Icame back to start a new print, and I noticed it was clicking while printing. It would be fine for outer layers that the printer would go slow on, but once it started on infill again the clicking started and basically sparce filament was coming out. I have taken apart the extruder assembly to make sure no stray filament pieces were there, the hotend isn’t clogged, but still clicking. Also, is the big yellow gear suppose to be sticky or have residue on it? I am not sure what else to do!
Also, when I first start a print, and the printer is going through it’s intial setup purging filament it starts working fine. About halfway through purging the clicking starts which causes it to purge and purge and purge. Then, when it finally starts printing, the first layer or two seems fine. But, once it starts into the infill the clicking starts happening badly, and the head keeps going back over to the poop cutter to purge and then back to printing. Hope this helps explain it.because I don’t know what to do after taking everything apart already.
