I have an A1 printer that got all plugged up with filament but cleaned the hotend and heater and I have been able to print several different models but then a few days ago, it stopped heating the extruderagain, so I changed the hotend heater after all that when I got it all back together it, I go into the control option, I set the extruder temp to 200 degrees it only climbs to 43 degrees C. What else could be wrong and what should I check?
Thanks!
Is there a chance the heater wasn’t installed properly and heat isn’t transferring to the hotend properly?
Did you use the Bambu wiki article as a guide for the repair you performed?
Objective confirmation would help - Got a thermal camera, or some way to measure safely? If it says it starts at 20c [guess] and ends at 43c, it would be good to know if it is actually 43c or if its actually getting red hot from a bad thermocouple. Either way it points to something being hardware bad, and support can probably help tease out if its a board, a component, a wire, etc. I would open a ticket.
