Today I noticed a bug when uploading new models to Makerworld.
When trying to upload a parametric f3d file, the validation fails.
I am sure, that my model is fine, since I only wanted to split up a model which worked before already ( the Gridfinity Shelf from this model Modular Shelf for HomeRacker by KellerLab MakerWorld: Download Free 3D Models is what I wanted to extract).
What I tried:
- Reupload a slightly modified version of the file to rule out the possibility that Makerworld validates file checksums to prevent copyright infringements.
- Did this by 1st renaming the original file
- then by doing a slight modification on parameter default values.
- Lastly I modified the default parameters to a “quick compute mode” (small values to be less compute intense on pattern multiplications)
- Double checked my browser adblockers to be deactivated on makerworld
- Used a guest profile in Chrome which definitely doesn’t have any cache or storage whatsoever
- I also tried different fusion models which I know all work normally.
I noticed a few odd things in the console though:
- There’s a CSP error popping up:
Content Security Policy of your site blocks the use of 'eval' in Javascript - And there was also a suspicious console log:
Uncaught (in promise) Error: A listener indicated an asynchronous response by returning true, but the message channel closed before a response was received
Did you recently change your server’s CSP settings?
Is this the right channel to address such a topic?
