For me i cut the ptfe tube tip that go in the head. I can see it is used so i juste cut it an put it back in And it worked
Hey guys, recently had this issue. I’ve already taken apart the extruder, cleaned the sensor, done cold pulls, pretty much everything and I’m still having issues. Anyone else have any suggestions?
TLDR, don’t forget to check your filament for a few loops.
I was getting this error. I started halfway through a 23 hour print. I went down the rabbit hole nozzle clogs, opening up the extruder gear assembly, checking ptfe tubes, everything listed. Got to narrowing it down to my AMS units and my other printed fine. After that I started swapping spools around, I finally discovered the below bulge, a few loops into the middle of the trouble spool. It looks like a filament join to me, but I wouldn’t expect that. This was a brand new Bambu Labs PLA mat spool. Cut it off and it’s printing fine again. ![]()
