Hello I have the P1S Printer with the AMS and i had a failure mid print. Instead of having to print all over again or having to put two halves together i opted to try printing on top of the failed print with limited success.
Can anyone help me figure out what i need to remove from the GCode so it dosent auto home and continues from the current height?
; EXECUTABLE_BLOCK_START
M73 P0 R1228
M201 X20000 Y20000 Z500 E5000
M203 X500 Y500 Z20 E30
M204 P20000 R5000 T20000
M205 X9.00 Y9.00 Z3.00 E2.50
M106 S0
M106 P2 S0
; FEATURE: Custom
;===== machine: P1S-0.4 ========================
;===== date: 20251031 =====================
;===== turn on the HB fan & MC board fan =================
M104 S75 ;set extruder temp to turn on the HB fan and prevent filament oozing from nozzle
M710 A1 S255 ;turn on MC fan by default(P1S)
;===== reset machine status =================
M290 X40 Y40 Z2.6666666
G91
M17 Z0.4 ; lower the z-motor current
G380 S2 Z30 F300 ; G380 is same as G38; lower the hotbed , to prevent the nozzle is below the hotbed
G380 S2 Z-25 F300 ;
G1 Z5 F300;
G90
M17 X1.2 Y1.2 Z0.75 ; reset motor current to default
M960 S5 P1 ; turn on logo lamp
G90
M220 S100 ;Reset Feedrate
M221 S100 ;Reset Flowrate
M73.2 R1.0 ;Reset left time magnitude
M1002 set_gcode_claim_speed_level : 5
M221 X0 Y0 Z0 ; turn off soft endstop to prevent protential logic problem
G29.1 Z0 ; clear z-trim value first
M204 S10000 ; init ACC set to 10m/s^2
;===== heatbed preheat ====================
M1002 gcode_claim_action:54
M140 S55 ;set bed temp
M190 S55 ;wait for bed temp
;=============turn on fans to prevent PLA jamming=================
M106 P3 S180
;Prevent PLA from jamming
M106 P2 S100 ; turn on big fan ,to cool down toolhead
;===== prepare print temperature and material ==========
M104 S230 ;set extruder temp
G91
G0 Z10 F1200
G90
G28 X
M975 S1 ; turn on
G1 X60 F12000
G1 Y245
G1 Y265 F3000
M620 M
M620 S0A ; switch material if AMS exist
M109 S230
G1 X120 F12000
G1 X20 Y50 F12000
G1 Y-3
T0
G1 X54 F12000
G1 Y265
M400
M621 S0A
M620.1 E F399.119 T240
M412 S1 ; ===turn on filament runout detection===
M109 S250 ;set nozzle to common flush temp
M106 P1 S0
G92 E0
M73 P0 R1226
G1 E50 F200
M400
M104 S230
G92 E0
M73 P0 R1222
G1 E50 F200
M400
M106 P1 S255
G92 E0
G1 E5 F300
M109 S210 ; drop nozzle temp, make filament shink a bit
G92 E0
G1 E-0.5 F300
G1 X70 F9000
G1 X76 F15000
G1 X65 F15000
G1 X76 F15000
G1 X65 F15000; shake to put down garbage
G1 X80 F6000
G1 X95 F15000
G1 X80 F15000
G1 X165 F15000; wipe and shake
M400
M106 P1 S0
;===== prepare print temperature and material end =====
;===== wipe nozzle ===============================
M1002 gcode_claim_action : 14
M975 S1
M106 S255
G1 X65 Y230 F18000
G1 Y264 F6000
M109 S210
G1 X100 F18000 ; first wipe mouth
G0 X135 Y253 F20000 ; move to exposed steel surface edge
G28 Z P0 T300; home z with low precision,permit 300deg temperature
G29.2 S0 ; turn off ABL
G0 Z5 F20000
G1 X60 Y265
G92 E0
G1 E-0.5 F300 ; retrack more
G1 X100 F5000; second wipe mouth
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X100 F5000
G1 X70 F15000
G1 X90 F5000
G0 X128 Y261 Z-1.5 F20000 ; move to exposed steel surface and stop the nozzle
M104 S140 ; set temp down to heatbed acceptable
M106 S255 ; turn on fan (G28 has turn off fan)
M221 S; push soft endstop status
M221 Z0 ;turn off Z axis endstop
G0 Z0.5 F20000
G0 X125 Y259.5 Z-1.01
G0 X131 F211
G0 X124
G0 Z0.5 F20000
G0 X125 Y262.5
G0 Z-1.01
G0 X131 F211
G0 X124
G0 Z0.5 F20000
G0 X125 Y260.0
G0 Z-1.01
G0 X131 F211
G0 X124
G0 Z0.5 F20000
G0 X125 Y262.0
G0 Z-1.01
G0 X131 F211
G0 X124
G0 Z0.5 F20000
G0 X125 Y260.5
G0 Z-1.01
G0 X131 F211
G0 X124
G0 Z0.5 F20000
G0 X125 Y261.5
G0 Z-1.01
G0 X131 F211
G0 X124
G0 Z0.5 F20000
G0 X125 Y261.0
G0 Z-1.01
G0 X131 F211
G0 X124
G0 X128
G2 I0.5 J0 F300
G2 I0.5 J0 F300
G2 I0.5 J0 F300
G2 I0.5 J0 F300
M109 S140 ; wait nozzle temp down to heatbed acceptable
G2 I0.5 J0 F3000
G2 I0.5 J0 F3000
G2 I0.5 J0 F3000
M73 P0 R1221
G2 I0.5 J0 F3000
M221 R; pop softend status
G1 Z10 F1200
M400
G1 Z10
G1 F30000
G1 X230 Y15
G29.2 S1 ; turn on ABL
;G28 ; home again after hard wipe mouth
M106 S0 ; turn off fan , too noisy
;===== wipe nozzle end ================================
;===== bed leveling ==================================
M1002 judge_flag g29_before_print_flag
M622 J1
G29 A X0.38139 Y25.441 I253.117 J195.441
M400
M500 ; save cali data
M623
;===== bed leveling end ================================
;===== home after wipe mouth============================
M622 J0
M1002 gcode_claim_action : 13
G28
M623
;===== home after wipe mouth end =======================
M975 S1 ; turn on vibration supression
M106 P3 S180
M104 S230 ; set extrude temp earlier, to reduce wait time
;===== mech mode fast check============================
G1 X128 Y128 Z10 F20000
M400 P200
M970.3 Q1 A7 B30 C80 H15 K0
M974 Q1 S2 P0
M400 P200
M970.3 Q0 A7 B30 C90 Q0 H15 K0
M974 Q0 S2 P0
M975 S1
G1 F30000
G1 X230 Y15
G28 X ; re-home XY
;===== fmech mode fast check============================
;===== nozzle load line ===============================
M975 S1
G90
M83
T1000
G1 X18.0 Y1.0 Z0.8 F18000;Move to start position
M109 S230
G1 Z0.2
G0 E2 F300
G0 X240 E15 F6400
G0 Y11 E0.700 F1600
G0 X239.5
G0 E0.2
G0 Y1.5 E0.700
G0 X18 E15 F6400
M400
;===== for Textured PEI Plate , lower the nozzle as the nozzle was touching topmost of the texture when homing ==
;curr_bed_type=Textured PEI Plate
G29.1 Z-0.04 ; for Textured PEI Plate
;========turn off light and wait extrude temperature =============
M1002 gcode_claim_action : 0
M106 P2 S0 ; turn off big fan
M106 P3 S0 ; turn off chamber fan
M975 S1 ; turn on mech mode supression
; MACHINE_START_GCODE_END
; filament start gcode
M106 P3 S150
;VT0
G90
G21
M83 ; use relative distances for extrusion
M981 S1 P20000 ;open spaghetti detector
; CHANGE_LAYER
; Z_HEIGHT: 0.32
; LAYER_HEIGHT: 0.32
G1 E-.8 F1800
; layer num/total_layer_count: 1/617
; update layer progress
M73 L1
M991 S0 P0 ;notify layer change
M106 S0
M106 P2 S0
M204 S200
G1 Z.4 F30000
