Feature - Bed Temp in multi-color prints
Can you please add a default option (at the printer level) that is set to true which default sets the entire print to the highest bed temp for any filament used in the print when printing multi-color?
Issue:
When using multi-color prints, bed temp differences between filaments sometimes cause the print to pop off the build plate even when as small as 5C.
Example
When I print Bambu Basic PLA by itself, I only need a bed temp of 55 typically, but I have other PLA and PLA+ that requires 60C for a textured build plate.
If I print them together, the bed temp difference causes issues and the Bambu Basic PLA pops off the plate because it drops the bed temp when that filament is printing.
While I can maintain separate profiles, Bambu Studio now limits the number of separate profiles I can maintain and it isn’t as cost effective to always run my Bambu PLA at 60C on an X1C as it isn’t always necessary.
Created an feature issue in github also for tracking. Not sure which place that developers look for these ideas first.
