I have exhaust to outdoors and like to run exhaust fan while using chamber heating. Firmware doesn’t allow this directly, and there are workarounds, but I’d like to be able run exhaust fan at 10-20% while chamber heating with ABS/ASA.
The workaround is to use g-code in filament start that changes mode to cooling, turns chamber heater on to desired temperature, and turns on exhaust fan. I couple this with a cover for the top front vent, a sealed purge chute, and I get negative pressure the entire print, with chamber heating. No smell as the exhaust is running the whole multi-hour print.
It would be much easier to just be able to enable exhaust fan in heating mode. No filament g-code needed, and no top vent cover needed.
Yes, continuously vent outside rather than accumulating fumes that otherwise do leak out in long prints.
I do it all the time currently. I only have about 6 feet of ducting. If I had much more, I’d put an inline fan in the ducting near the exterior end pulling air through it.
The idea is to maintain negative pressure inside chamber, so that any leaks are inward, not outward. The cost is you are exhausting some of your heated air, so chamber heater has to work harder.
I have been somewhat passively trying to figure out the same thing. Have not settled on a satisfactory solution yet.
BUT! Here’s what I can say. The exhaust fan at 20% doesn’t even open the lightweight, gravity closed louver I put over the outlet outside. This may be due to it simply leaking past the louvers, or it may be just not strong enough to push any air at all through that duct. I intend to one day steal a smoke generator from my cousin’s auto shop to find out however right now I am leaning towards installing an adjustable speed 120v, 120mm fan in-line.
I just need to figure out a means to trigger it on-off when the printer is printing. Somehow. Possibly involving current detection and a timer relay. Haven’t gotten that far yet.
I use the printer’s local MQTT status to trigger my external fan. I built a small Python service on an old Mac that controls my Smart Life fan through Tuya, waits for the chamber to warm, and runs a 15-minute purge afterward. It only reads printer status and never sends the printer commands. I wrote up the setup and code, you can find it on my github danielyaa5; mine is an H2D with a Tuya fan, so it’s a reference for the approach.
I ended up doing this. The printer’s vent fan stays off, the auxiliary fan pulls a small amount of air through the printer, and I have zero styrene smell getting out into my house as a result.
It’s still not automatically enabled, but that’s not a real problem either. I’ve been running back to back ABS jobs for almost a week so I just turned it on at the start and it will stay on until I pull the ABS out of the AMS.
Downside is if the printer’s fan is running the auxiliary one will just freewheel. Maybe I will print a dual blast gate diverter to bypass the fan when I am using the printer’s built-in one. Or not. Replacement fans are cheap as chips.
