Feature Request: Face-Based Slicing Modifiers (Surface / Face Painting for Slice
Feature Description: I would like to request a feature that allows users to apply slicing parameters (such as wall loop count, infill density, or infill pattern) directly to specific faces of a model, using an interface similar to the current Color Paint / Fill Tool.
Currently, modifier shapes (cubes, cylinders, or imported meshes) are clumsy to align when trying to target specific complex surface regions—like the interior cavity of a pot, vase, or container.
Proposed UI / Workflow:
  1. Select a tool similar to Color Painting (e.g., Smart Fill, Brush, or Fill).
  2. Instead of picking a filament color, select a Setting Modifier Preset (or assign a “Surface Modifier Zone”).
  3. Click/Paint a specific face or region (e.g., the black interior face in the attached screenshot).
  4. Override slicer settings specifically for that surface or the perimeters generated behind it.
Primary Use Cases:
  • Different Inner vs. Outer Walls: Setting global wall loops to 2 for the outside of a pot to save time/filament, but painting the interior face to use 4 walls or concentric infill for extra strength or watertightness.
  • Localized Structural Strength: Adding extra walls or dense infill behind specific functional surfaces (like screw holes, snaps, or load-bearing faces) without creating separate CAD modifier geometries.
  • Surface-Specific Textures/Infill: Applying different top/bottom shell patterns or wall counts to selected visible faces.
Why Current Workarounds Fall Short:
  • Global/Part Settings: Changing “Wall Loops” on an object applies to all perimeters (both outer shell and inner boundary), offering no distinction between inside and outside faces.
  • Standard Modifiers: Aligning primitive modifier shapes to tapered or complex inner geometries (like conical pots) is extremely difficult, prone to errors, and requires re-modeling auxiliary shapes in CAD.
Having a “Face Modifier” or “Setting Paint Tool” would save a significant amount of CAD work and give users fine-grained control over local part strength directly in Bambu Studio.
No they’re not.
The move tool has X/Y positioning and quick alignment for front/back/center and left/right/center that allows modifiers to be placed with perfect precision and repeatability.
For the specific use case you’re citing, it would be relatively simple to design a shape in CAD that matches the interior surface of the pot, with a thickness equal to however deep you want the modifier to extend. Import the modifier and place it using the same X/Y coordinates as the base model.
Would be a lot cooler if you could just click the inner face though.
Bambu Lab is targeted at people who don’t have CAD experience. Surface painting is an easy to teach process. CAD is not.
I think it’s an excellent suggestion. I might not need it, you might not need it, but I think a lot of other people would find it just as useful as filament color painting. That also being a thing nobody “needs”, because you can just model the different parts in CAD and assign them different filaments.
A good tool makes hard things easy. This is a hard thing for most people.
This is why we are here and why modifiers don’t always work. Also the last 2 purple layers are missing no matter what I change, and the bridge is printed in the air. That means throwing away a roll of filament and 20 hours of printing. And when dealing with oval shapes, even if you use a modifier to set an inward offset of, say, 1mm and specify two 0.5mm concentric walls, the infill effectively disappears in certain areas depending on the height, or you end up with a single line or three lines instead of the two identical ones you selected.
Problem i have with modifiers is that when you for example change number of walls or infill, it does not connect the 2 areas in a strong way. it’s like 2 separate prints side by side.
i tried to make a one piece vehicle chassis with a weaker upper body and stronger wheel mounts, and I gave up using modifiers; I had to make them separate parts.
Yes, I know. And also is create another external wall inside.
