Feature request from BL or Makers
I am new to BL ecosystem. I am away from my PC and printer most part of the day and I have only few hour to design and start a print. If need to print something from Makersworld, instead of spending that limited time searching a model while at home, I try to choose one using the handy app during my idle times.
I like the the way MakersWorld structured. Being able to see the approximate time and filament need to print the model/profile is great. But profile info chart does not show the dimensions. Unfortunately majority of the uploader do not mention the dimensions in their description either. The only way i can see them is downloading it to Bambu Studio and measuring it. Which means i have to go back home re-search and download model… Which drains the limited time i have.
It would be great if BL adds an auto-calculated dimensions in to the info charts. Only projected L/W/H dimensions will be enough. This will allow us to decide if it is the right size for our needs or how many (different) models we can fit on a plate. Rescaling does not work well especially with functional parts.
If BL can not implement this, I suggest/request/beg from uploaders to add these manually to their descriptions.
You can see the dimensions in Bambu Handy already.
While you are on the Prepare to Print screen, you can click on 3D Preview. Here you can look at the models on the print plate you selected.
Once you are in the 3D Preview, you can see the dimensions of the part.
I can not see that dimensions when i browse the makerworld page with PC. I did not think it will be available in handy version. As I can not see anything on phone good enough and also still afraid to send print while i am a way i did not try to send print from handy.
Thanks for the heads up.
For multi plate builds, it would be nice to have the completed object dimensions documented. For example, a 10 plate treasure chest size can be estimated by adding part dimensions but noted dimensions would be helpful.
