Feature Request - Print Chamber Temperature Control
My shop is too cold in the winter to print even PLA without first preheating the chamber, so I can see how your code will save me a lot of manual monitoring and chilly trips out of my office. Thank you!
I do suggest you modify the description to indicate the code is really only useful for an X1C. The code will not work with a P1S or enclosed PIP because they lack a chamber temperature sensor. An X1E or H2D should not need the code.
Also, the code does require OrcaSlicer. Studio does not support the Chamber Temperature setting in the filament profile. The setting does not even appear in the Studio profile editor unless you first select an X1E/H2D printer.
