Filament jammed in AMS and printer prints without filament
While printing on the P1S, the AMS 2 started flashing a red light indicating a filament jam (PLA Basic), but the printer continued printing without filament. No error message appeared, what could this be?
A clogged nozzle or try to print too fast for the filament could be the issue. The extruder will grind a groove in the filament and will stop feeding but continue to print.
I printed the same item (the first time without any problems) with the standard 100% settings (PLA Basic). AMS2 showed that the filament was blocked, but the printer was printing, so the problem likely lies with the printer’s software, which is not responding to the AMS signal. If this happens again, I will file a complaint for the entire set.
Sorry to meddle, but the same is hapening to me right now, but I have AMS 1 and no red lights or any sign from AMS side or printer, the Filament just wasn’t being released and printer was making the moves on the air, I lost a bunch of filament already, PLA, PETG, I tried to change nozzle heat, cleaned the cogs, nothing seems to make a difference. Any ideas?
Disconnect your PTFE at the AMS and at the extruder and manually feed a piece of filament through your whoke feed path; you need to feel for high resistance or a sudden increase in resistance.
Something is stopping your filament from feeding freely.
TBH I don’t think this is it, I did it already several times, I even disassembled all the cogs and cleaned 3 times, I had to change the nozzle due to blob, the old nozzle is fine, but the thermistor wasn’t, so I upgraded for a hard steel nozzle one, and it worked fine in the beginning but now startet to do that… I’ll try to go back to the old nozzle and see if it works, for what I read before it seems that I had to change the cogs as well… not sure, I’m new at this and there’s too much conflicting information, but thanks for the answer my friend
I don’t think you even read what I wrote - I didn’t say anything about messing around with nozzles, i’m trying to diagnose your feed path first.
