I would like to ask for a different option when filaments runs out.
We know we can use a backup filament, if is identical (or, at least, if you cheat and say it’s identical), and if you prepare everything before the print starts.
I would like to have the option, via Bambu Studio and Bambu Handy (especially), to say “OK, continue the print with the filament in slot 3”. Often the print need a perfect match for the colors, but also need no match at all, things you want to hide, to color, things useful but with no aesthetic, etc.
So, if I have a similar filament in the AMS, I would like to have the option, when I’m away from home, to force the print to continue with the filament in another slot.
My printer just notified me that the spool of filament has run out—even though Bambu Studio’s calculations indicated there should have been enough left. The print had been running for 12 hours, with another 4 hours remaining. So here I am at work, just waiting for the day to end so I can rush home and move a new spool into the empty slot. I could have easily reassigned the print to use a different spool of the same material type (the model itself allows for this), but instead, I’ll have to wait another 5 hours—during which time the printer will just sit there, heating up the air inside the chamber. It’s clear the developers couldn’t care less about scenarios like this. Yet, this exact functionality has been available on the A1 series printers for two years now; on those models, you can reassign the color or type of filament mid-print, and the AMS will automatically pick up a different spool. For some reason, however, this feature still hasn’t made its way to the company’s other printer models, even after all this time.
