Filament track switch for only 1 AMS and 1 AMS HT. Yes or no?
I have the H2C and only 1 AMS and 1 AMS HT. I don’t do all that much color changes, so this setup works for me.
The filament track switch is cheap enough. I just don’t know if it would be used that much in my situation.
Is anyone with my type of set up getting it?
Thanks, Cody
I just got my hands on X2D with AMS 2 Pro and AMS-HT. Pro goes to left nozzle (main) and HT goes to right nozzle (aux). I also have a y-splitter on main path after the buffer and I use this for bypassing buffer from the bypass port on the HT. I use the bypass for TPU (soft) and for PA (hard/brittle). There’s a really nice bypass clip on Makerworld for the HT, which replaces the stock rubber and uses a PTFE connector (the smaller type) and this keeps my main/bypass lines connected permanently. I just need to remember that bypass goes to main nozzle. With this setup I’ve not needed the track switch, which I’ve been considering since getting this setup. After having used this setup in the manner described I am not feeling inclined to get the switch. However….
I have a P2S with Pro and HT AMSs. So I may consider getting the track switch in case I want to gang the two Pros and HTs to the two nozzles - for some reason unbeknownst to me presently so this feels unnecessary. Most of my prints are 1-2 colours so dual nozzle is awesome and I try to print single colour parts or print by object to reduce filament use.
