Hi, just wanting to know if it is possible to control the filament path on this multi colour print im trying. Currently some white will be extruded in an area where there should be red. I’ve tried smaller line width and layer height but the result is the same. Any suggestions on what else to try?
Try setting the Slice gap closing radius and Resolution to 0.001mm
Is this this your own design or an external design you want to print.
