Only been doing this less than a week so bear with me. I did several prints without issue using Release 01.09.01.00 on my Bambu P1S with PLA. When prompted I updated to 01.10.00.00 and immediately experienced problems. The print head did not release cleanly from the end of the purge line, instead dragging it across to the main model and corrupting the print. I reverted to 01.09.01.00 and again printed several models without any issues. I repeated this as a test and experienced exactly the same. There appears to be a problem with the latest release at least on my printer. Has anyone else experienced similar?
I am running 01.10.00.00 on my P1S with no issues. If you want to try again, you may want to do a factory reset and be sure to perform a self calibration after the update.
I will give that a go but I would like to have a few more successful prints with no issues before I do so. I can’t recall but I may not have reset and re-calibrated after the update although I certainly did after restoring the previous version. Thank you.
