Print it front of the aux fan, and set the aux fan to 100%, you should be able to print it using 35mm³/s, also you need to use a filament that can handle fast printing.
AUX FAN at ASA? Surely it will then detach from the plate, but I can test it.
But for now I have the original nozzle on it again.
ha sorry, did not see your previous posts
I had the copper insert CHT nozzle installed for about two weeks. It allows higher flow but also started causing issues in general print quality (small extrusion faults, less sharpened print). Just not as reliable than stock nozzle. I switched back and maybe try in the future again if a print really benefits. The printer is already lightning fast with “limited” flow…
NZ$ 16.32 | High Flow Upgraded CHT High Flow Hardened Steel 3-Hole Nozzle, High Temperature of 500 ℃, Compatible with Bambu Lab X1 Carbon
https://a.aliexpress.com/_mrs5sRa
Hardened steel cht nozzle, correct height for aftermarket hot end.
Just ordered my hardened cht nozzles, would like to try 0.6. Anybody have any tips on config or profiles for 0.6 nozzle? Would the volumetric flow in the filament settings change? E.g. i’m currently using 34vms but imagine that may go up with a larger nozzle hole? Thanks.
ordered 0.6 & 0.4 ![]()
Me too. 2x 0.4 and 2x0.6 + 2x spare Hotends… I ordered also some PAHT-CF and I dont have a 0.6 so far. Lets hope this 0.6 CHT work well with the bambu PAHT-CF.
Ordered 0.4 and 0.6 ![]()
Thank you
Aliexpress closed my order order for the 2x04 and 2x0.6 nozzels tonight and I got my money back…
Do anyone else have the same issue?
Same here, even if order is still possible
Anyone thinking a Cease and Desist order was issued?
Interestingly the multi-part insert nozzles were brought up it the interview with Dr Ye Tao earlier today and basically his opinion seemed to be that it was fine, but a direct copy and sale of their hot-ends would not be.
Did u reorder them? Or found them from another seller?
I have tried a re-order
I placed a new order by this shop: https://www.aliexpress.com/item/1005005599312011.html?
That is exactly what we need. The airbrush design is nearly perfect for getting ultra fine details. I just dont like the problems you mentioned. If Bambu could design a nozzle shaped like this, we could have the next step toward perfect fdm printing. This airbrush shape does nearly zero ironing while printing but this design has it flaws. You need a 1.7mm wrench and its very vulnerable. If we can get a nozzle made of one piece and maybe even hardened it would be a god send upgrade ![]()
Wow that looks metal. and thats with cht nozzle from Ali and Polymaker ASA black ??
