Hi, can someone please help me with what may be causing these bumps around the edge of the infill please?
I’ve tried flow rate and dynamics calibration, as well as raising and lowering the nozzle temps.
The filament is Bambu PLA Matte.
Thanks!
Thanks!
Is that the bottom layer or the top layer? And why is the print so bent? And what layer hight are you using? What extruder nozzel are you using? Sorry for so many questions but I need more info to help.
Hi! Thanks for the reply.
It is PLA and that is the first layer 0.2mm thick from a 0.4mm nozzle.
The print is bent as I removed it from the bed in a huff when it was still warm! ![]()
I have the problem on the initial layers of every print regardless of the thickness of the first layer.
