First layer - extruder too high
I have a problem now, after updating to bambustudio 2.6.0.51
I cant print anything as for every print (that was working before update) when first layer should be made, extruder is way too high.
It is visibly so high above the build plate so there is no way it will deposit any material on to the surface.
Did anyone run in to similar problem?
Cris.
Have you tried restating the printer and re-doing a calibration? What printer are you using?
