Hello , I bought my first bambulab x1c .
I had a k1 max but decided to change .
I’m using default profile 0.08 mm extra fine to print a Batarang but I’m not happy about first layer .
As you can see in the picture , there are a lot of lines and I would like to have a uniform bottom layer .
First picture shows x1c model , second shows the same model printed with Creality k1 Max .
How can I have the same results ?
Which parameters recommend to change ?
Thank you
Hi
Maybe this can be of a help:
To summarize: I invested some time for testing but was not able to completely remove the lines!
hello , thank you for you answer. did you try to play with z offset ? I’m using cool plate bed and I’m not able to low the z offset.
No, because I don’t see what value it would add. Increasing the flow should have a similar effect as keeping the flow and reducing the z-distance.
