First long print (35 hours) PETG stringy and gaps in print
If you print a part that is a single layer of PLA between your PETG parts instead of an air gap your will have enough support and adhesion to print the next part on top without the air gap and you will be able to easily separate the parts after printing. PETG and PLA do not bond well. You will need to create a part that is 1 layer thick that matches the shape of the top of your part and assign an AMS slot that has PLA filament to that part and place it where the air gap is now.
Now that you know that the source of your problems was stacking the models in order to save time…
Looking back, how much time did you really save?
The OP didn’t say it was a stacked print. That of course radically changes the “problem set”.
Stacking doesn’t save time. Stacking lets you print more objects at once, so you don’t have to be there to clear the build plate and start another print run to get all the objects printed.
If the time required to remove a part and restart the printer isn’t included, printing parts one at a time or all at once doesn’t make a difference. How long it takes to run a print is mostly a function of the sum of the print times of all the objects regardless of the order in which they’re printed.
If you use the PETG from Bambu the settings are all there and it works much better than ALL of the cheeper filaments. I learned the hard way and now ONLY buy Bambu filament.
Hi @Chris1974
The pursuit of optimal efficiency is always “a thing”. Professionally, i own and operate a firearm suppressor company and run CNC mills, mill- turns, and routers daily. In that context, chip control, tool life and breakage, surface finish and many other aspects com into play when developing machining programs. It takes more time to develop a machine cycle that does 20 identical parts at a time, but to be able to hit “cycle start” and walk away for 8 hours is awesome. Automating CNC operations is the holy grail of making your machines work off their cost, but one tool breaking our slipping out of spec reverses that payoff quickly.
In response to your question, i learned that stacked printing results in cycle times that are almost too long, which is what i was eluding to in an earlier comment. I think you’re inadvertently correct… stacked printing doesn’t save much time, but not because stacking models caused problems (much like @RocketSled pointed out) . On the contrary, one i figured out some temperature stuff, it worked relatively well. I don’t like tying up my machine for that long, but it works, and if i were to be leaving for a couple days, I’ll probably do it again to get the most out of the machine. But on a normal day all you gain is not needing to clear parts in between cycles and not waiting for the bed preheat/ automated bed labeling, etc.
I do appreciate your point, though, and recognize the logic in your statement. Thanks for your time and input.
Cheers!
This is something i want to try, but haven’t dug into using the AMS to run multiple filaments in a single print, yet. I agree that this may be a better way to achieve quality stack printed parts.
Looks like WETG to me, do you print from a drier?
Also petg is always stringy on the inside of a hollow cylinder. You are making a micro oven with the nozzle and heated bed. I cannot find a solution for this. I made some knobs once and no matter what I could not get the hollow interior clean.
Hi Stinger, in my opinion, the temperature does not affect your print, and also the settings are not at fault in your case. Your problem is the LACK OF EXTRUSION. If it’s generated by a CLOGGED NOZZLE or a problem with AMS, or the EXTRUDER!
I do not know! Somehow, not enough filament passes through the printer nozzle.
Clean or replace your NOZZLE, dry your filament … I recommend to try with other brand …
Go with Bambu Slicer Basic Settings … and see what happen!
Cheers!
I think the problem with PETG printing is the nozzle, which is steel and not brass. There are some temperature differences. Brass has better heat stability than steel noses. That’s why PETG prints come out poorly.
For example, my prusa printer, if I use a hardened steel nose, the print tends to come out poorly. However, everything prints well with a brass nose. I believe that the problem is in the metals and not in the software issue.
My x1 carbon prints pla, abs, tpu and tpe and carbon filaments very well. But PETG filament really doesn’t work. But is PETG filament so important?
