I stop wasting time with this topic that seems to be a reproach for good software often misused.
Good continuation, without me.
You must be check spotiflyerapp.pro also.
I also use Onshape and there are so many free models out there that its easily lost in the volumes. I would recommend the you do not label or name your designs in an obvious manner but rather use a code name e.g. “Ku771ng b04rd” instead of “cutting board” or something to that effect. It should keep it out of the searches. You can also make a very basic sketch on the first tab and then your proper designs from the second tab, as it often uses the first tab as a thumbnail. That’s been working very well for me thus far.
I would also advise that you consider the paid tier if your design does hit the jackpot to show appreciation for all their hard work that they make available for free.
