That is exactly my question as well. I have opened up a ticket with Bambu Support (because apparently I am a glutton for punishment), and have been working through their initial standard answers and suggestions.
They suggested I go through this guide: H2C First Layer Print Quality Improvement Guide | Bambu Lab Wiki
However, after doing everything on the list to ensure everything was tightened correctly and even manually leveling the bed (tramming), I’m still getting the same results that point to the nozzle being too far away from the bed. For their tests with that guide they are only using a single large square, and I’ll admit, when I printed that after doing all the calibrations, it looked pretty decent, only like 1 small section had disconnected lines. But, when i started printing some different shape objects I’ve printed on my P1S in the past, I could definitely see how the nozzle was too far away from the build plate causing lower bed adhesion (inner circles). Pictures included, you can see each individual line and the inner circles are pulling away from the other lines.
Even after doing all their calibrations, I’m back to adjusting the gcode to get a better first later on my H2C.
The z-offset is one of the big issues with the H2C default configuration which is causing first layers to be poor quality, especially with multi-color prints. However, through my testing, as i described, individual nozzles are also giving me slightly, but noticeable, different quality (under extrusion). So, there doesn’t seem to be a single solution to this problem, but I also miss the consistency I have with my P1S. I bought Bambu because I wanted it to be plug and play, and get away from days and weeks of testing settings and “dialing-in” a printer. Hopefully Bambu will realize this issue and change the z-offset. I think if they just did the same z-offset for the H2C textured plate as for the P1S (-0.04mm), it would drastically improve the majority of users’ experiences. Then the other issues can be ironed out more efficiently.
