I am fairly new to 3d printing itself and hope that you more experienced people can help me out.
I have an issue when using my H2D printer with two AMS 2 Pro and 8 different colored filaments inside, all PETG-HF.
Firstly, the AMS are both connected properly to the printer: one 6pin cable from AMS to AMS, second 6pin cable from first AMS to printer. Also, they are correctly shown in the setup/device menu of Bambu Handy App and the printer menu itself. I can use all options there including RFID filament scan, drying (got a power supply to the 2nd AMS) etc. The first AMS is connected to the left nozzle, the second AMS is connected to the right nozzle.
My issue:
When I want to print stuff from maker’s world via Bambu Handy app, only the 4 filaments of my (second) AMS, which is connected to the right nozzle, are shown. There is no way that I can chose any filament of my other (first) AMS, which is connected to the left nozzle.
How can I solve this and change to the other nozzle i.e. the other AMS/filaments?
When preparing the print in the menu, where I chose the filament (and use either filament saving or comfort mode - same filaments options shown in both), there is a small text which states “recommendation: right nozzle”.
I guess it has to do with the software or settings of the maker’s world creator, since there is no option to change the recommendation which nozzle to use.
Does this differ on the Bambu software for PC?
Could you please help me out? I would like to chose between every 8 colors via software. Right now, I am just swapping the AMS which are connected to the right nozzle.
The left nozzle itself is working though, when I disconnect the PTFE tube that connects to the right nozzle, so when only one AMS is connected.
Maybe for testing purposes, can you recommend a model that uses multicolor print with both AMS preconfigured?
I’m experiencing the same problem. I can (after synchronising) use all my filaments on both the Mac and Windows clients but not in the handy app. That looks like a bug too me. NB: I use three AMS 2 Pros .
just for the record this bug also affects you if you move the ams from the right nozzle to the left nozzle. you can see the ams but when you go to print it no longer seems it as being attached…
I did have this the other week; I did not know what the xxxx I just turned the printer left for a bit, and it was ok for now.
One of my other Ams2 i have from beginning just goes to feed it in. Just keeps feeding it and then comes up with a fault.
I should just have got 2 normal AMs; I would not have had the trouble all the time with it.
It does not work for me. When I want to reprint and change the AMS, I cannot select any AMS other than the one connected to the initial nozzle of that print. May be it works for a new downloaded model but not for reprints. Well, I think for reprints you cannot do it anyway as the gcode already has the nozzle in the code and cannot be modified.
This is happening to me. Just bought everything. Only the screen to choose a filament when trying to print is missing my second ams2pro . Otherwise the app shows it and has the colors
