This morning I sent a print from the calibration tab to perform flow calibration on my printer. However, the machine is waiting at the nozzle change point. And it never moves. It gives an ams mapping table error as an error. Bambu lab says it is related to the memory card, but changing it did not work. I need support quickly for the problem.
I have the same error.
Seems with the new printer out they start to screw up the old devices.
Nice!
Yes, I agree with you, I hope it will be fixed. But I don’t know what will be our delay. As a result, we can’t use the device’s feature ![]()
Question have you tried power cycling the printer?
Yes, I tried everything you can think of, I even did a reset, but this is completely software related ![]()
I also reformatted the sd-card and tried orca.
Filaments show up in print preparation and device settings but under calibration it only shows ext. spool. If i try to manually load a slot the menu item appears but the printer will heat up and stay very long until the error message appears.
I did not try to get calibration going with external spool as a workaround.
Im pretty sure they messed something up while integrating ams2/hms .
Curious, what firmware and slicer version of BS are you running? Is this a P1S or is it a P1 that was upgraded? I have seen a few threads about people haveing issues with BS 2.x on there upgraded P1 and BS refusing to believe it is a P1S. Your issue does sound a little different.
I had the same issue with both my A1 and A1 mini. BS only showed the external spool but not the AMS Lite. this occurred with both of the printers so I know it is the software. U switched back to Orca, which is what I prefer anyway. I just wanted to try out the new BS. Its layout is nice but I still prefer Orca.
In other recent threads i read that they will deliver a hotfix asap.
