Food for thought, recent cyberattacks on networked HVAC
I’m sure the supermarkets who bought cloud-enabled “smart” coolers are reconsidering the wisdom of their choice and putting those things online.
A cloud-enabled bambu [and others] printer is listening/longpolling the internet to receive commands from you. Those commands can heat up the bed and nozzle to maximums, use the nozzle as a grinding tool onto the plate, extrude an entire kilogram of plastic, and other various nefarious actions. I’m very sure the attack surface on a printer is very different than those hvac controls, and likely much harder to breach, but make sure you’re accepting the correct amount of risk with the machines in your home. Claude et all are getting very good at this sort of thing.
I’m just Some Guy© on the internet, but I recommend to not allow internet connectivity, ideally implemented on your router. If you need to remote manage it, stay in LAN, and use a VPN to get into your LAN.
Two important points:
  • The incident was not a hack nor a real cyberattack, but simply outdated software that hadn’t been updated for decades. The security vulnerabilities had been documented for decades, but nobody cared. We’re really talking about decades here - no exaggeration.
  • Now, regarding 3D printers: I could write a novel about this, but I’ll keep it short: These, too, can be remotely controlled from outside under certain conditions, as the CCC has already demonstrated. The advantage, however, is that most printers are still receiving updates; the situation is different for printers that have reached the end of their life cycle.
So, what’s the bottom line?
Are Bambu 3D printers 100% secure? No. But neither is any other internet-connected device.
That said, Bambu printers are not inherently less secure than comparable products. In fact, they are generally in a better position than devices that have reached the end of their lifecycle and no longer receive security updates or technical support. As with any connected device, regular updates, proper network configuration, and ongoing vendor support play a key role in maintaining security.
One easy security step - don’t leave it on when not using it. Not practical for all, and it is an inconvenience, but it saves idle power draw too.
