My print just failed at the 18-hour mark of a 26-hour print. Not because of spaghetti… or part failure. but because it failed to unload the filament. This has made me beyond upset. The only way to access the head mid-print is to turn off the machine. Failing the part. I cannot load a new filament to try and push it out at full temp, cause it paused due to the error not allowing me to extrude filament or load filament. NOR can I change the temp of the head to try and force it out as well. I should be able to decide if I want to try to load a filament and force out the gunk at that error. At least giving me a “Chance” to save my print.
