Forklift lights activated by using forks
Not sure if this is normal behaviour on the forklift but I am able to switch the lights using the proper light switch, however, if the lights are off, they turn on again as soon as I move the forks up or down. I can’t see how this would be due to incorrect wiring, so it’s normal (and undesired by me) or a code bug?
Bei der Programmierung der Fernsteuerung, musst du nur beim R SHOULDER STICK das Event Setup löschen. Dann blinkt es nicht mehr beim bewegen der Gabeln.
