FTS before I take it out any view
There is a thread on here where a user disassembled the FTS and smoothed out the switch lever because he thought the internal resistance was too high.
I am not directly recommending that, but mentioning this to support might help here.
But as @CarbonForge mentioned, sharing your setup might get you some tips.
Thanks, I took the whole setup apart so will take a photo when I put it back together
I took the FTS apart too just the outer case to see if I could see anything then I manually pushed filament though
by hand as soon as it’s in the FTS it becomes stiff and harder to push through, then if I push it though backwards it’s easy until about half way in then becomes harder to push through again.
I can see why it’s saying there is resistance if even manually it’s harder to get through
As I don’t have an FTS myself, I cant judge how much resistance I feel for comparison.
But it’s definitely worthwhile to report this to support and verify if this is normal. Also other users on here should be able to give feedback on that.
I presume you tested with PLA/PETG. Fiber filled filaments will definitely add more to the resistance.
Also interested to see your setup.
Ok tried this, basically as short as humanly possible tubes without putting in a right angle, gets to FTS then audibly louder resistance then the error
give up, it’s going back for a replacement unit
Hope you get it resolved. When it works its a nice QOL upgrade.
in case it is useful to someone in the future,
I have made progress with this, I pushed filament back through it the wrong way around (in through out hole) and tried again, interestingly if the filament goes through A it doesn’t error, but through B it does
the only difference I can see is I have a 4:1 on B so it must be FTS on B issue or just the total resistance is too high overall
Final post as I figured it out (but can’t fix it) in case this helps somone. I fully dismantled the thing and rebuilt it and noticed on one side the leaver that moves via the magnet opened fully when done manually but when using the thing rigged up without case when I moved it manually no error but when it was left to do it on its own the leaver only opened to about 70%, the it would error. I moved the electro magnet around and it just wouldn’t fully open it, if I let it try and then manually intervene I could still open it so that’s my issue there is a range of motion issue when the magnet is used.
anyway it’s defective and sending it back
