This might sound obvious to some but I am trying to print Tags for nfc chips and a couple of designs that I have found when I go to slice them I get a warning that says there is g-code modifications and to check and make sure it will not damage my printer, how do i know if it will damage my printer or should I just avoid these designs?
Do they have pauses in them to insert the tags?
Yes, they both have pauses in them.
If you export the geometry and open that file, you shouldn’t get an error. Then you can insert the layer pause manually and be sure it is safe.
Thank you I will try that, thanks for the help. ![]()
