Generic PLA profiles changed for the worse?
Hey there,
i just printed from generic PLA profile and the printquality got exceptionally…bad! Idk what happened here over the last firmware updates of the X1C and the software updates of Bambu Studio, but to me it looks like the generic profile became unusable.
In the past it just worked, printed prints in decent quality and it was a convenient way to do quick’n’dirty test prints.
…but what i got now is:
  • bottom layers and walls not connected, there are big visible gaps
  • support structure really is a pain to remove
  • saggy lines on bottom layer directly above support structure
i never had such issues using this lazy way of generic profile with Sunluu PLA+ before.
(Sure, i know…i could tweak the profile or use a custom one or a Sunluu provided one. Yet this is not subject of this issue.)
The whole area was fully supported with standard support. All plain standard settings of the 0.2mm profile. The only thing changed was from 2 to 3 walls, nothing else. Officially the worst non-failed print i pulled out of this printer. :clown_face:
Just did some further check using the Sunluu provided profile.
Did flow rate and dynamics calibration and a temp tower to refine that profile.
Same issue with the first layer right above the support top layer with standard support settings.
Seems like it is not an issue of the generic profile but rather sth. went off with the interface between support and part bottom layer above the support.
Refining top layer spacing for support to 0 from 0.5 does not help.
…And Orca seems not to be working with the latest X1C firmware, yet.
—> Anyone else got similar lack of print quality when it comes to interface between support and part at standard settings?
