Global fan speed modified during printing
Hello,
As you can see from the image, the %fan speed is modified throughout the print run, resulting in a change in the appearance of the layers on the final printed part.
I’d like to know how to set this %fan speed to 100% for the entire print run?
Thank you in advance !
Léopold
Salut :wink:
Check inside “objets” if there are range modifiers that change the speeds of the walls. Remove them and it should be good
Thank you for your reply.
I’ve checked and can’t find a speed modifier. Concerning the printing speed, it is homogeneous on the whole part (see attached picture).
So maybe there is a postscript added.
If I remember well, it’s located somewhere in the bottom of the tab “Autre” in the print settings.
You might need to enable Developer Mode (inside app settings) for this setting to show up.
