This all looks very strange; it’s possible that a rare error occurred during an update, damaging the area where the serial number is stored. In any case, you have only one option: open a support ticket and contact Bambu regarding this issue. No one else here will be able to help you.
Did open a support ticket about 9 hours ago, thanks
I doubt that area where the serial number is stored could be damaged in this way, one would also presume that chips storing S/N would be non-writable, but here we are. I was writing here out of desperation and if someone experienced the same issue. And since the S/N was rewritten somehow, I believe (coming from computer science area) it should also be fixable with custom BBL signed firmware update. But again, it is probably easier/faster for them to ship new AP ![]()
You are mistaken. New AP boards are supplied without a serial number; once a new board is installed, you must write your serial number onto it via the Bambu servers and support. The SN can be written at least once.
It’s incorrect new AP board comes with a new SN, the support ticket is required so that the new SN gets linked to your account
I was one of the early victims of the AP board glitch, before the jumper workaround, so they sent me a new AP board.
The new board absolutely came with a SN already loaded. I read the new SN off the printer’s screen and sent them a picture of it so they could bind it. It wasn’t the other way around.
I can not 100% confirm that the problem is solved. I was effected by the H2C not Booting up issue. After the firmware upgrade I made 2 or 3 power cycles and my H2C booted up every time. No problem s far. If the problem is 100% solved I do not know.
I don’t see anyone asking this about using those power plugs. Are you sure it is ok to just kill the power on a plug for these printers? I mean they do have computers in them. Is it ok to just kill the power like that at the plug, it would be just like pulling the plug from the wall while it was on. I was thinking of getting one of those plugs and just want to make sure it won’t hurt my H2D or coming H3C.
Feel free to purchase and install it. The switch on the back of the printer does the exact same thing: it cuts off the mains power supply to the printer’s power unit. There is no difference between turning off the printer by unplugging it from the wall outlet and using the switch on the printer itself.
I also have my printer connected to a remotely controllable power outlet; for instance, I use it when a print job finishes during the night, scheduling the power to cut off 30 minutes after the print is complete. My only concern is that the printer shuts down without me having pressed the “OK” button that appears once the print job is finished. Could this potentially be an issue?
I don’t think so. The only potential issue could be if the print stops for spaghetti o whatever and the filament would be still loaded. But I think it shouldn’t be a big problem…
I read it on Reddit thatthe H2C has AP board design issue that can’t be fixed by firmware updates. They have to fix the hardware design and recall all the board for all these printers. Likelihood of this happening ? zero percent.
So, I guess Bambu will address the issue as people complaint about the issue.
Not sure if this is true or not as there is not information from Bambu on this.
Pulling the plug is no different than flipping the power switch on the back, thats exactly what it does, cuts power.
The AP board is the same for the entire H-series. The only differences are the firmware and the internal serial number. You shouldn’t believe everything you read on Reddit. If the issue were with the board design, then the H2D and H2S models would also have the same problem.
I would think, there might be a bad batch of AP-boards out there, but as @maxspb69 already mentioned, I can’t believe they are all bad.
Then the forum would be flushed with people complaining.
And for Bambu Lab it’s easier and cheaper to replace the affected boards instead of a mass replacement for all the printers out there.
Also not everyone is willing or able to do the replacement and possibly a lot might have already sold them.
I can confirm this does NOT fix the issue where the screen won’t come on after power loss. I hit that issue for the first time today when dealing with an AMS issue, and I am already on 01.03.00.00. (The workaround to short the 2 contacts did work to bring it back).
I think there may be some newly introduced AMS 2 Pro issue though, it is refusing to load filament to the extruder, claiming that it will not load into the buffer. The AMS feed motor (the one right before the PTFE exit of the AMS) is confused or something. I’m about to file a new support request for it
Today I updated my H2C to the last version and the issue of printer not booting up is still PRESENT. I’ll open a ticket with the support.
Since the firmware update on my H2C, I’ve been having serious issues with my two AMS HT units connected to the left nozzle. There might not be a direct link, but the problems have become very noticeable only since the update. Spools are frequently failing to be detected, and there’s an occasional clicking sound during the rewinding process—as if the filament is getting stuck somewhere and needs to be forcibly pulled free. Is anyone else experiencing the same thing? I plan to downgrade the firmware in the next few days to verify if that’s the cause.
Attributing AMS mechanical issues to the printer’s firmware—that’s quite a bold claim! And it’s pointless. No one experiences such issues with any firmware version. You will need to open up your AMS units and look for the problem along the filament feed path.
When the main motor hub bearing in my nearly new AMS2Pro failed—causing a knocking sound during filament feeding—I didn’t go looking for issues in the firmware; I simply replaced the bearing.
The filament path is clear! When a spool is inserted, the detection procedure runs to completion. The loading icon spins on the printer display, and once finished, a question mark reappears. This is suddenly affecting both of my AMS units. Even trying a different spool doesn’t result in proper detection. I’m not looking to cast blame on anyone; I’ll perform a firmware downgrade in the next few days and see what happens. We’ll see how it turns out. If it still doesn’t work the way it used to, I’ll simply reach out to support.
Since I updated to this firmware version I’m having this weird issue with the right extruder picking up the wrong hotend. For example: in Bambu Studio I assign nozzle R1 to a filament but the printer picks up nozzle 6 from the rack. Same with assigning R2 and it uses number 4…
Already removed and replaced all the nozzles and did a read all, but no change.. Anyone else encountering this issue?
