H2 Extrusion Gears
In the middle of an ABS print.
Extruder stopped pulling filament.
Tore toolhead apart and I cannot find anything wrong. I can push filament down to do a clogged head pull, but it will not pull the filament itself.
The gear turning indicator shows the gears are turning.
Did the filament pulling gears wear out this fxcking quickly?
  • Dave
There is a common problem with some batch of gears. The wheel comes loose from the spindle, inspect it.
Well, I am order a few. I would love to order the filament sensor at same time (cause I know one of these days, I’ll tear the flex cable.
I tore it all apart because I could not get filament to feed through the extruder. It would get so far and no more. I thought it was jammed.
If it was I never saw a reason for it. Upon taking it apart the first time, that tension spring sprung hit the walls and bounced around.
When I re-assembled, I put the silver cap on the wrong end of the spring and the machine screw had nothing to push again.
So I am dumb as usual.
Now the funny thing, I repeated the head clog pull a second time. Each time, there was still white ABS on the sides of the black ABS.
Maybe it was a head clog all along?
The head clog removal procedure in the H2S is brilliant! I wish my K2 Plus Special POS Edition model, and X1C had that (I haven’t looked through the X1C’s menus for a while, maybe it has been added).
So, I think I solved my own problem that I was panicked about an hour ago. That seems to always happen. I ask for help and then solve the issue shortly afterwards.
This could be a lesson, look at the part replacement guide first. I put several gears in my shopping cart and then noticed right on the part sales page they have a link to instructions on how to replace the part! BAMBU Labs is brilliant!!
I have one other issue tonight, that cannot be solved. Earlier today, the Refill spool came apart in the AMS2. I KNOW I had it together correctly to begin with! I lost a new roll of ABS. Maybe that is why not to buy refills. I am going to try to unspool half the roll, throw that bunch out and save the last half of the roll, but I do not have another idea. These are grey BAMBU LABS PTEG refill rolls that I bought from EBAY. Bambu didn’t have any stock at the time. Maybe this is why the guy was selling five of them. That is non-sequitur to this topic; sorry.
You could open a support ticket for the issue. But having been through all the stages you have been through, I am not sure you can define the initial issue clearly to support.
Still worthwhile trying.
Trying to find on their website to message support should come with a free package of cheese if you can find it. I emailed them with another issue last week, they emailed back the next day saying they do not except email support requests and then provided the link. I followed it and have yet to receive a reply. Since then the fine fokes on here helped me out and I ordered more parts, and for now, have it solved.
I do tend to panic as first when I run in to an issue, and I do not know why I do. I am good at electronics, and have been my whole career, but mechanics sometimes cause a panic and loose patience; dunno why. Then for an hour or so last night, I learned how to tear the extruded head apart and put it back together about four times (4th time was the charm) and learned out how to de-clog the head. It’s not that I am bad with mechanics, they just always scare me. Short term memory of how something came apart, and which screw goes where, can cause anxiety with me - lol. I must say, Bambu spent a lot of time creating their step-by-step tear down and part replacement guides.
The idea for opening a ticket was more so you didn’t have to pay for the replacement parts.
And yes, it’s always better to read the wiki when you start taking components apart.
I am quite confident myself in taking apart electromechanical devices, but still some reading upfront helps to not overlook things.
I do okay, once I get going and have done it recently. It’s just that I tend to panic over a 10 minute mechanical fix. lol I don’t like my toaster breaking at the most inopportune time.
Yes, I was hoping they would say “Don’t worry we will send you some parts”. In this case, they told me the spare parts were included with the printer - lol. I already had just used those after sending them the support message.
